You think Toyota is bad. In my Holden Colorado work car the transfer shift is via push button on the dash. If you can't get low range you have to check the fuse for the reverse light switch. No reverse lights = no electronic transfer control. Not even the local Holden dealer knew that.
SOLVED - Urgent Help!!! Issue with no Indicators, Climate Control or Reverse lights
