LED Bar Fitted to an ARB Deluxe Bar - Pics wanted
  • #76
    And saw this at the Nambour Caravan & Camping show in the car park. "Not" a Prado or an ARB bar, but I liked the way the Baja Stealth LED Bar fitted up to the bullbar.
    Hope the owner put crush tubes as the vibrations will chew a hole in the horizontal tube.
    I like the Matsuda (Mazda for Westerners).
    I didn't notice that the top one was bolted through the bar. Ouch.
    • #77
      here is mine....only use it in the bush....
      • #78
        Yep, pretty sure this is what I will do with the Newpro tech one. Like you I will only use in the bush ("said very quietly - and on any shite that flashes his hi beam at me for more than 2 seconds)
        • #79
          Hi all,
          The prado is my quick fix to the mounting problem. It is a bit brutal but I needed a light for a trip to Fraser. After much consideration and a phone call to ARB this was sadly the best solution for a quick install. Amts I have put crush tubes in and it all seems to be holding up well. Once I get my roof cage back on the light bar will be moved there and then I have to work out how to best fix the damage my rush job created. In saying that it is a good place to mount it as it is out of the way of trouble but not in the way of vision like if it was top mounted on the bar.
          09 120 GXL. OME lift, Snorkel, ARB deluxe bar, magnum winch, CKMA12 under bonnet rear locker, AJ120 side steps, Amts bash plates, L.E.D light bar, ARB roof cage, M/T atzs, Uniden 105 sx, x-ray vision HID headlight conversion, TG120. More to come as always.
          • #80
            Looks great. What breed of mounts are you using there? They look like they get a bit more height than other ones I've been looking at, just what I need to get over the top of my XGT's.
            [FONT=Verdana][COLOR="#0000CD"]2008 GXL D4D Work in progress[/COLOR][/FONT]
            • #81
              http://www.newpro-tech.com.au/PDFgallery.htm
              Just get yourself a gmail web based email. She will never know. If your new to the deceipt game then be careful on the statement explanation, just label it "Care Aust Donate" This will also earn you brownie points when you explain the transaction as "I had to donate babe. That poor helpless child needs a well to grow crops or the drug lords will put her into prostitution and her parents will have to work for the labour party in what can only be described as an uncertain future.
              Then explain the new lights as you won them as a donator prize!
              I like your work, the idea ~ in theory is good, one day when we meet, remind me of this, and I'll shout you a beer!
              2005 Diesel Funbus Driver
