I am about to smash this bl*&dy thing, anybody tell me how to remove the tail light assembly from my 120 series, I have removed the 2 10mm bolts and removed the internal panels and pushed and pulled and swore but it wont budge, I even got the 5mm camera out but cant see anything, help please as the patients is failing fast.
tail light removal
All you need to remove is the 2 bolts, them pull them out. Pull them straight back and they should come. Left and right are the same, even with the door on the RHS it looks like it wont clear but it does. Maybe give the light a whack with the base of your hand to help it along.
There is no need to remove any interior trim as nothing but the 2 bolts holds them in.
Best of luck.
I think it took me a while the first time, always a worry that you have missed something and will break it.
Good you have it sorted.
Glad you asked the question Brett as I have to replace the brake light globe on the drivers side and undid the two 10mm bolts and pulled them out but couldn't budge the light so I whacked the bolts back in as I was in a hurry. I thought for sure I would be pulling the trim off but I did think I would check the service book first to see if it said in there how to replace it, glad Im not the only one lol........Cheers SteveFace lift 150 Prado V6 auto. No mods yet
It is the same for the 150 Bandicoot. Undo the bolts and it pulls out.2013 [COLOR="#006699"][B][SIZE=2]Blue Storm[/SIZE][/B][/COLOR] D4D 150 GXL Auto, Opposite Lock Bullbar, Safari Snorkel, GME 3345 UHF + AE4018 Antenna, HR Tow Bar, TG150, HD Rhino Roof Racks, Foxwing, Dual Batteries, C-Tek DCDC Charger, ARB 47L Fridge, ScanGauge II, Internal Fishing Rod Storage, X-Ray Vision HIDs and LEDs, New PP Sticker.... [COLOR="#808080"][SIZE=1][/SIZE][/COLOR]
