A lot easier way would be to take the wires off the heated rear screen ( never gets used anyway) and join the wires to the work light. The switch is already on the dash and all the wiring is done. Thats how I did mine ,,works for me.
Rear Work Light Install
Originally posted by raydes View PostA lot easier way would be to take the wires off the heated rear screen ( never gets used anyway) and join the wires to the work light. The switch is already on the dash and all the wiring is done. Thats how I did mine ,,works for me.
Originally posted by raydes View PostA lot easier way would be to take the wires off the heated rear screen ( never gets used anyway) and join the wires to the work light. The switch is already on the dash and all the wiring is done. Thats how I did mine ,,works for me.2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
Originally posted by amts View PostShould be able to wire the light to a switch and use a double throw relay driven by the reverse lights so that either the switch or reverse light will turn the light on.
Here's a quick sketch
[ATTACH=CONFIG]11290[/ATTACH]
You could use a two way (on/off/on) switch for the rear light where one way it switches to the 12V feed to your relay and the other feeds to the switch feed to the relay - that way you can have the option to turn it on, let it switch with the reverse lights or have it off.Last edited by Trekrider; 30-05-2013, 01:14 PM.
Originally posted by Trekrider View PostOne problem I see with this Andrew is that the rear light will always come on when in reverse. For a light mounted above the spare wheel I don't believe you should do this as Mr Plod may object - it is illegal to have a reverse light this high.
Originally posted by amts View PostI was thinking more about the pic that Jus10 posted where the light is in the center of the spare wheel. Would Mr Plod object to that one too?
Originally posted by Trekrider View PostYou could use a two way (on/off/on) switch for the rear light where one way it switches to the 12V feed to your relay and the other feeds to the switch feed to the relay - that way you can have the option to turn it on, let it switch with the reverse lights or have it off.
Obviously the other option is to mount reverse light down low off the tow bar and work light off pole attached to spare bracket - a lot of extra work for the minimal chance of trouble with po-po
Originally posted by shodown View PostHow many cops do you reverse in front of then? You would have to be pretty unlucky to have issues with police on this one - most would just assume it is a work light only....
I can see it now, you have the rear light on when reversing and some idiot runs in the back of you because he was texting and didn't see you. He claims he was blinded by your light and all of a sudden it's your fault and your insurance company doesn't want to know as you have an illegal light fitted.Last edited by Trekrider; 30-05-2013, 02:10 PM.
Originally posted by Palmer View PostIf I ever get around to fitting mine, I think I'll just go with a simple on or off. That way I can use it as light around camp plus, if needed, I can flick it on when reversing.
