hi all, just wondering if anyone knows where the reverse wire location is to wire up to my headunit?
Reverse signal wire location
Yep went for the light after MUCH searching, easy peasy.2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
4x4 History: 2000 Prado GXL 90 Series 1KZ-TE, 1992 4runner 2.8 Motson turbo, 1985 Landcruiser 60 Series 3.9L Diesel, 1985 4Runner 2L 2.4 Diesel later mod. + 2.4T (Factory Turbo), 1982 Hilux 2.2L Diesel in Yellow (callsign 'Yellow Peril') later mod. + 2.4L engine[/FONT]
Originally posted by Peter.Rocks View Posti found it finally! [ATTACH=CONFIG]13887[/ATTACH], took a little bit of searching, but it is the big plug at the bottom of the passenger kick pannel and a red with black stripe wire on it, very easy to get to and find
I found mine on the trailer lights loom rather than cutting into the main Prado brake light wires.2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
Originally posted by RanJ View PostLol so did you find it finally after a bit of or searching or was it rasy to get and find?
you just had me confused with your post mate.... finally found!... Easy to find! usually don't go together.
It's in one of the footwells in every car. If you have the time and the patience to find it, awesome. As a fitter, I don't have either. I need to get the job done reliably and in a timely fashion. Hence I use the reverse light itself as it usually takes me less than 5 minutes to remove the tail light, run a wire from the plug to the front of the car and secure it.
When determined to find it in the kick panel, I start by removing individual plugs to see which one kills the lights.
Originally posted by Anth120playdo View PostI did post that somewhere, not sure if you found it, but you found it. Good work either way.
http://www.pradopoint.com/showthread...rse+wire+w602c
access to a reverse wire, large, red with black trace, behind passenger kick trim, at the lowest plug. I used the reverse signal at the back to power the cam. Rather than put it in the door I fitted it above the tow hitch.
It's central, perfect to back over the trailers, it was very easy.
