Hello,
To assist with reversing I've added 2 LED lights to the rear of the car. I have wired the lights to the reverse wire on the trailer plug. Once the lights were wired I did a test to ensure that they were working correctly. They worked so I tidied up the installation - tubing, tape, cable ties and screwed the trailer plug back into place. I then tested the lights again and they are not working. The vehicle reverse lights do work. I stripped the cabling back to the join point and found that there is no voltage at the incoming trailer reverse wire.
Is there a separate fuse for the trailer loom, if so, where can I find it?
Regards,
John
Regards,
John
