I managed to get the final story on getting the rear fog lamps to work
You need to order:
1 x 84165-33040 - Fog Lamp Switch Assy
2 x 81591-60132 - Lens & Body
2 x 82214-60050 - Wire, Lamp
2 x Standard 12v clear lamps(same as the park light)
Simply insert the switch into the top left receptacle in the driver's switch panel. Connect the white connector, with the green line through it, to the switch (no need for any relays or additional wiring).
Remove the fog lamp 'blanks/dummies' from the rear bumper. Insert the 12v lamp into the wiring harness 82214-60050. Insert this into the new fog lamp housing. Insert the new fog lamp into the bumper and connect the grey connector to the male counterpart under the bumper.
Hey Presto!!!! Working fog lamps!!!
You need to order:
