Hi Fungi2003,
I am using Redarc controller which works fine. The problem is with the D4D alternator. The Alternator puts out enough voltage (around 13.3- 13.7 volt) to charge the main crank battery to start the diesel. Sadly it does not put out enough voltage to fully charge the Trojan deep cycle battery (approx 14.4 Volt). Therefore you never get the deep cycle battery fully charged unless you use a battery charger. Down side using only the D4D alternator - you will not get 110 AH from a 110 AH battery and the battery sulphates and has a reduced life.
John
John
