So my '04 Prado has started to give me a few starting problems. When you turn the key it gives about half a turnover and then you just hear a small whine and then some 3 or 4 seconds later it will either die or it will kick in to life. At first I thought the battery must be about dead but I stuck it on a charger overnight and it still did the same thing. Only happens some times and usually if it doesn't kick over first time then it will after the 2nd or 3rd try, another indication that the battery still has plenty of life in it.
Any clues?
It's due for a service but I would prefer to have an idea what I'm in for before the mechanic tells me the whosamacallit needed replacing at a cost of $2000-
Any clues?
