Accessory wire in engine bay - where?
  • Accessory wire in engine bay - where?
    Run a search and I can't find any of the so called green wires that have accessory power.
    Does anyone have a photo of accessory wires in the engine bay that can be used as a switching wire?
    120 D4D with nothing on it......yet.
    one on the wiper motor??
      Is ignition wire ok? There's one in the fuse box.
        Which one? I tried all the spare ones but they were either hot or not on when acc was on.
          Thanks. So being new to Prado's, where is the wiper motor?
            One of the terminals on a blank relay spot. It's ignition only.
              I'm after acc only, not ignition. It's for a USB outlet so I don't have to have the ignition on to charge a phone.
                Use the fuses under the dash. There's 2 ignition and 2 accessory fuses. All the fuses in the engine bay are active all the time as far I know.
                  Thanks Billzor.
                  Used the thickest green and white wire in the fuse panel at drivers right knee.
