Re: RanOx DC-DC(non 240v) 3 stg charger: **Install pics added**
John,
I too run two separate Aux. charging regimes.
1: Ranox (option 1) which is set for a max outputof 22A to match the battery.
2: Inverter & 30amp battery charger.
I too have noticed that the Ranox some times have trouble determining when the battery is running, especially so if both chagers are at capacity. I plan to change the Ranox to Option 0 but just haven't got around to it yet. I am currently using a 100A solid state relay to switch the feed to the inverter and will probably use the same on the Ranox.
These relays are available from Jaycar: CAT. NO. SY4086
Leachy
John,
Leachy
