Power windows when ign off.
    Re: Re:
    [quote=comp.dad]
    Originally posted by "Grey Nomad":1obkdjk6
    Hi 2003GXL
    I guess that you have a 2003 model. When I was travelling last year, I met a bloke who saw my modification and wanted me to do it to his. So I got out my little "document" (as shown above) but his plug and socket were different even though his was a 120 series. We were out in the bush with nothing but a multimeter and soldering iron and I couldn't find a permanent source of +12v on his plug. So I politely declined. Maybe yours is different to the diagram shown above and maybe you got your source of permanent +12v from somewhere else that has somehow interfered with your central locking.
    That's why I mentioned that not all Prados are the same. However, on saying that, this is really quite a simple modification that I have done to many cars over the years.
    Cheers - John
    Thanks..
    Will try on teh weekend.. My 2008 gives me teh usual 30 sec grace... But coming back 20min later and having to use teh key is a pain..[/quote:1obkdjk6]
    Simpler than I thought :-)
    Now as soon as I can get a spare switch or two... I may just replace the link and teh cut wire with a switch; that way I can have the system as standard or free control as and when needed / required.
    PS. Any one know the best place to pick up good quality switches that suit the Prado's
    WARNING: On my Prado 2008 this mods then activates some security and you can NOT start the car :-(
    Will have to look at just shorting and not cutting the White wire.. Or if I wire it up correctly... It will allow the windows to be operated but disable the car... NEAT :-)
    Now where to get some quality switches...
    Ability is nothing without opportunity: Napoleon Bonaparte:
      been a while since anyone has commented on this. so has anyone done this of late or done something different to gain same result.
      does anyone know if different models/years require a different approach
      i am particularly interested in 2005 grande model
      any comments
      [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
      ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
