Hello to all in pradoland.
I am far from an electrician. I used to be able to lift heavy things though.
I am in the process of adding an auxiliary battery. So i am now
looking for a hot wire for the solenoid controller. Which wire do you use/splice into? I have fitted the arb tray which is mounted over on the passenger side. I have run most of the wires and mounted the solenoid.
Any help would be much appreciated.
Steve
Steve
