Hello everybody,
I live in Panama Rep. Panama, Central America. Here nobody sells the Parrot CK 3100 LCD bluetooth hands free, So I will order from USA.
I have a 2007 Toyota Prado, Gasoline engine 4-cylinder 2.4. Here I have attached a photo of the factory radio my Prado have.
Here are my questions:
1) Have any of you has install a Parrot CK 3100 LCD in this radio?
2) Do you have pictures of where you installed the Parrot digital display on the Prado dash. This way I can take some ideas were to intall it. better.
3) I've looked at the Parrot web page http://www.parrot.com for the adapter ISO cable for my factory radio but my car model is not listed there. Any idea were I can order it and what model I have to order?
3b)Do I really need this adapter cable or can I connect/hard wire it without this adapter?. I refer specifically if the instructions that come with the Parrot explain clearly where each cable goes.
4) Once installed the Parrot, it is necessary that the radio is on to make it work? Or even with the radio off it will work and I going to listen thru the speakers?
5) I will use it with a Blackberry 8300 and Nokia 6230
6) Any suggestions?
Thank you very much,
Isaac
Image link fixed by Mod.
6) Any suggestions?
Isaac
