Thats the problem 120P..you tend to look at what everyone else is doing and then want one as well.
Rear work/spot light install
Job for the weekend....Got a really nice 4bar LED from Narva which will fit nicely under the back of the Rhino rack. I have the ARB touring rear awning like Matts so I don't want too much heat near it...hopefully this should do the job... I got the 800 lumen one because I don't want to burn my retina out while I'm making my coffee!http://www.narva.com.au/products/bro...red-light-bars
In that position I'm hoping it will be effective to light up the rear door table which I often use as a kitchen.
pics to come[COLOR="#000000"]2003 Grande, Maxtrax,ARB rear and side awning, Rhino rack, GME 3100 UHF, Sony 2DIN DVD/reverse camera, 2x 9" headrest DVD's + 2x 7" headrest DVD's, Aries sheepsking custom covers, 2" raised kings, ARB underbonnet high output compressor, Hybrid dual battery with fuse box and additional outlets in rear, Rear door table, High power reverse LED flood, Staun deflators, ARB snatch hitch and strap, PP sticker[/COLOR]!
DPDT Wiring diagram
Hi
Just installing work lights onto my 2005 Prado and want to use your suggestion of using a DPDT Switch.
Looking at your wiring diagram are you saying the power sources go to pins 1 and 4 with pins 3 and 6 used to connect to relay?
Any help much appreciated.
David
Originally posted by leachy_9 View PostBrett,
What you want can be achieved by using one relay and a Double Pole Double Throw switch with a stable off position in the centre (DPCO). Below is a circuit showing how this can be done.
Leachy
