Food for thought for other petrol powered Prado owners....
A tip here is you can basically get relays/fuses and fuse links from auto wreckers for free if you're ever in there buying something else. Also, there a fairly universal part across many makes and models.
Another tip for those less mechanically minded is to do a basic automotive maintenance coures at somewhere like TAFE. With a little knowledge relays and fuses can be substituted from other systems to get you going, for example you can do without the heater fan or headlights if you need to get the EFI/Engine up and running.
Mick
