Been hearing for a while that running with your fog lights on in Illegal in most states even during the day.
I am one that likes to run with foggies on as i feel that they are less dazzling than HID low beam during the day.
Since being reminded at a Random Breath Test of the new rule I have gone looking for a solution.
The ADR's have approved the Hella Daytime Running Light,
This is good news for all you ARB Bar owners as i think (Havn't confirmed) that these ones here will fit in to the fog light holes.
These are available from all Hella stockists They are available in round or rectangle, i am working on fitting the rectangle ones on a toyota bar. May also fit between the ARB split pan
Specs Below
5607 LED Daytime Running Lamp Kit
Description: Universal round daytime running lamp (DRL) equipped with 3 x high-performance LEDs and high-sheen metallised free-form (FF) reflectors for a superior signal pattern and maximum visibility to oncoming traffic during the day. Automatically switches on when the engine is started and switches off when the main headlamps are activated or the engine is turned off. Robust, die-cast aluminium housing with cooling fins and clear polycarbonate lens for increased durability.
Set of 2 lamps supplied with pre-assembled professional harness, relay and waterproof AMP plug.
Voltage Multivolt (9-33V DC)
Suitable for 12V and 24V vehicle electrical systems.
Wattage 12V <5W (single lamp)
Mounting Upright or pendant. Universal mounting bracket included.
ADR Complince No 76/00
ADR Function: Daytime Running Lamp
Specs Below
