Redarc have just released a new DC-DC 3 Stage 20 amp Charger. ( see photo 1 & 2)
http://redarc.com.au/products-and-servi ... start-bcdc
The great thing about this unit is it will accect anything from 9 - 32v DC input.
The unit will work with a choice of three battery types - AGM/Gel, Calcium Calcium or Lead acid.
and uses a three stage charging process to charge the second battery.
http://redarc.com.au/static/files/BCDC1 ... t-A5-1.pdf
And its Australian Designed and Built.
The compact size would make it great for the caravan or camper trailer, or for mounting to a portable battery box.
So I thought I would install one of these units into our 2006 Diesel Prado
to charge our Aux battery.
The unit is fully sealed so it's fine to mount under the bonnet.
I used the Piranha Battery tray from TJM to mount the second battery. (see Photo 3)
Then installed the BCDC-1220 on the Drivers side inner guard, just above the ABS pump. (Photo 4,5&6)
Will report back in a couple of weeks to let you know how its performing.
But I already have the Redarc Battery Management system fitted to my camper Trailer and it uses the same 20amp DC-DC charger and it's great.
You can read about the redarc BMS and my camper trailer fitout here if your interested.
http://www.campertrailers.org/smart_start.htm
Rod
Photo 1 Redarc BCDC 1220
Photo 2 Redarc BCDC 1220 from above with wiring
Photo 3 Piranha Battery Tray from TJM
Photo 4 Redarc BCDC From Above Drivers Side Inner Guard
Photo 5 Redrac BCDC 1220 From front of Car
Photo 6 Redarc BCDC 1220 Installed prior to wiring up
Rod
