OK so i have decided on my camper if you can call it that a Goldstream storm and i am figuring out my anderson plug wiring options now my question is as follows
As i already have a duel battery management system i was planning on just running the anderson plug wiring straight off the aux battery.
Now i understand by doing it this way the camper battery and the aux battery will be drained if i leave the anderson plug connected when stopped however does current flow back upstream as my camper has a built in Cteck changer for when 240 is avaliable if i leave the anderson plug connected will the camper and the aux battery be charged with wiring as above or does the current only flow 1 way
Hope this can be understood as i dont know much about wiring
