Re: Wiring an Anderson Plug
Geez, what an afternoon to install the Anderson Plug.
37degrees at 5:30, concrete even hotter, but I only had the crimpers for the afternoon, and the cold beer was singing..
Got it done, hooked directly to the +ve and -ve of the Aux battery, thanks D4D.
Ran the cables down the drivers side, up over the rear wheel arch, then in behind the rear aircon unit. There is a bung hole used for the rear lights (I think) dropped the two cables through there, wrapped in split tubing all the way and screwed the plug to the top of the towbar plug unit thingy. Plugs in sideways.
Volt meter shows the same voltage at the Anderson plug as at the battery, not bad for an IT nerd Thanks PP..
