Bought some air horns today
Need to wire up some air horns and want to put in a switch so I can choose between OE "hello" horn or the new triple "get out of the f$%ing way" horn.
I am having trouble finding a wire for the old horn anywhere under the steering column or dash. Consequently I might have to run wires from the old horn itself back along the engine bay, through the firewall to my switch.
Any clues.
Cheers - Byrnsie
Re: Bought some air horns today
Originally posted by McBAIN
there was a video that did the rounds a while back of some guys that had fitted a train horn to their car and drove around town setting it off.. very very amusing!!!Glenn
2012 GX TD 150 with long mudflaps - [url]http://www.pradopoint.com/showthread.php?23370-Yota-s-150[/url]
1996 GXL TD 95 with no mudflaps (sold) - [url]http://www.pradopoint.com/showthread.php?12402-My-Truck-quot-Build-Up-quot[/url]
Hi Burnsie,
Be very carefull mucking around with the horn wiring or the horn button/airbag assembly in way of the steering wheel, as there are strict instructions to follow to remove the horn button/airbag assy. even just to trace wires.
I wired my relay directly to the low note horn using a spade terminal it is just the mater of opening the bonnet and reconnect the one horn for the two Tojo horns.
Using this method of wiring, when you touch the horn button for a pedestrian you just get a gentle beep as the relay delay and air compressor run up times gives you this slight delay. If the pedestrian eyeballs you and rudely keeps on walking against the red light then you just keep you hand on the horn for about 0.75 sec and the pedestrian Sh##ts themselves.07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Burnsie, I'd be keen to see the wiring diagram for the switch. It's pretty much exactly what I would be after as I am certain that when my 3 year old is waving goodbye saying 'Daddy beep' he would be traumatised by 139db of air horn.
Let us know how you go and some pics would be useful.Neil - Porsche 911 (997.2 2009) Carrera S
I fitted air horns smack in the middle, in front of the radiator. Mine are similar to the pic at the top of the thread; two trumpets and compressor all in one convenient unit. The trumpets squirt noise into the back of a TJM-style steel bumper. The claimed 139dB or more is probably at four-inch range, but they're still stupidly loud. In a sort of freight-train way. I'm well chuffed.
The compressor inlet includes a fitting where a plastic hose (not supplied) can be added so that the air intake can be moved to where it won't ingest muddy water.
As for the electrics, the power to a relay comes off the original horn spade connector. The compressor draws nearly 10 amps. In the unlikely event that I have to disable the air horns and stick with the original feeble Toyota offerings (113dB according to what's written on them), I'll simply pull the fuse on the power supply between battery and relay.]}:-{>
[b]2004 VX V6 120 4-speed auto[/b]
OME lift, safari snorkel, steel bumpers, ally bash plate and LightForce spotlights. Still working on it...
Well Grumpy,
Sometimes we must be inovative and supply our own bit of plastic hose :!: I do like that feature in the horns where you can have the compressor air intake above expected WL's07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Originally posted by YotaOriginally posted by McBAINWe used to have air horns off an XPT train on our fire truck, back when we were alowed to modify them.
Mitch[img]http://i49.photobucket.com/albums/f296/1cut808/MUMSRIG/Mitch-Prado.jpg[/img]
Curiosity got the better of me today. I wanted to hear what these horns sounded like. I went to the Stebel website and found that you can select the horn you want under the products page and then play the horn sound. Not a bad site! It's a good sounding horn too.
The website is:
http://www.stebel.it/stebel/index2007_1.htm
To try out the compact air horn, go to Products, select the Car icon and then the Nautilus Compact Series button above it. You can then select the horn icon which plays the soundAndrewH
08 Prado VX D4D, ARB bullbar, Warn 9.5XP winch, Bilstein/Lovell suspension, Polyair's, ARB diff locker & air pump, Safari snorkel, Ausguard cargo barrier, Lightforce 170 HID driving lights, GME TX3440 CB, Brown Davis bashplate, Sandgrabba Mats, Scanguage II, Rotronics independent 3 battery management (3rd in camper), Kenwood DDX8039 with Nav, Reversing camera and sensors, Blaupunkt compact powered woofer, Custom drawers, Bushman fridge, Cooper ATRs onroad & STTs offroad, PressurePro 6 wheel TPMS, Steinbauer Module.
I too have a new horn....
Ended up with a slightly different Stebel
"STEBEL NAUTILUS COMPACT TRUCK HORN 12 Volt 300Hz 134Db"
It has a lower frequency sound, more like your Mack Truck..
Got it for $75 (pick up) @
http://stores.channeladvisor.com/Onl...0300Hz%20134Db
I'll try the install this weekend.Neil - Porsche 911 (997.2 2009) Carrera S
I like the idea of getting some of the 'nautical' horns. Just to confuse those idiots who drive around with their fog lights on all the time because can't help themselves :lol:My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
