Re: LED worklight
hey nick i ran 3.5mm twincore from a switch through the rear door cable grommet cut a little slit in and ran it up the outside of the rear door jam onto the roof and under the black plastic trim on the roof and onto the rear crossbar and up onto the rack, on the light i put waterproof plug just incase i want to take the rack off. cheers samo
here is a foto of the plug, $14.00 from repco and yes i reused the same cable
