Im sure this has been discussed before but haven't had anything pop up which properly answers my questions fully, just bits n pieces of info everywhere
Headlight globe (halogen original) H4 has gone so am tossing up which way to go. Have read some leds produce too much heat, may cook the inside of the headlamp assembly ???
Was using Phillips upgraded halogen globes in a Vitara previously and they kept blowing constantly so wont be buying anything Phillips.
Supercrap Auto have some Narva globes, and wondering if any of those are worth the 70-100$ tag, anyone used them ??? Or do i go the Fleabay route
So for those of you that have had both , what are your recommendations and if you have any globes you think are good, a direct link would be good if u can be bothered. And id like a simple install, no adjusting cutting or whatever. BTW running standard suspension atm also
cheers folks
cheers folks
