Headlights stopped working after battery disconnected
  • Headlights stopped working after battery disconnected
    I had a headlight globe stop working and replaced two globes. Tested before I put everything back together then everything stopped working. No high beam no low beam. Must be a simple thing. Did search and found nothing. What have I missed
    Cheers Brian. 2006 Grande D4D
    Fuse, relay?
    What did you disconnect (battery?) and test before putting back together? Is it just one-side or both that are not working? Everything else working okay?
    Prado_The_2nd now on my Third Prado (and 2 Landcruisers before that!)
    2012 Altitude, Petrol
    ARB Deluxe Bar, Towbar, Driving Lights and bits and pieces of other tech.
      Forgot about fuses. Reading another post on here triggered my brain. Found two headlight fuses had blown. Replaced and all fixed. Don’t know why fuses blew. Thanks for your reply. Cheers...
        No prob. When two things go at the same time, makes it 4 times as tricky to diagnose! Blew two headlight globes on the same day once ... spent time testing fuses before thinking to swap a globe out!
