Hello chaps. Dumb question I know, but I thought I would check for ideas before I do it the hard way. Have run power to the back of the Prado. Just need to connect the fused cable to the positive battery clamp (specifically the bolt on the top). Buggered if I can get the top bolt to move, and worried I may damage the clamp if I go all out. I removed the clamp from the battery post so I don't flex/damage the post. The Toyota clamp is not a solid unit and seems a bit flimsy and difficult to find a secure footholdn the clamp so I can get some decent torque on the top bolt. Anyone out there had the same issue before I end up bending/damaging it?
Positive battery terminal top bolt seized
