Does anyone know where the probe is for the temperature indication that is next to the clock? My wife keeps asking me and I have no idea where it is reading the air.
Outside Temp Gauge Probe
Re: Outside Temp Gauge Probe
i think it is located left to the horns , center of the radiator
i found it while replacing transmition oil cooler
hisham[COLOR=blue]2006 VX ,5 Auto , currently Scan gauge II , Bonnet Guard ,wind deflectors,head lamp cover, dust deflector,insect net , Engel fridge,IPF fat boy,Hella FF300 lights,Toyota HD bars,BF 265/70 R17 A/T, Hella TPMS, K&N,OME 2",DBA , AirLift 1000 & Wirless Air control , ARB Comp,Safari Snorkel.[/COLOR]
[URL="http://www.fuelly.com/driver/hisham/prado"][img]http://www.fuelly.com/smallsig-metric/52690.png[/img][/URL]
Originally posted by hisham saeedi think it is located left to the horns , center of the radiator
hisham
...and what a wonderful location it is in too!
Right next to a major heat-source, with relatively little air-flow even when moving...
I've extended the wiring and moved it over to one side, behind and below the passenger-side headlight, where there is some airflow.
Makes a big improvement to the accuracy of the "outside" temperature.Rob.
'08 GXL V6 Manual with: O/L Bar, Cibie Oscars, Safari Snorkel, Revalved Ironman 45710 Struts & 45682 Shocks, Dobinsons & King springs, MickeyT STZs, Eaton E-locker on rear, ScanGaugeII, InaWise TPMS, and a Tvan controlled via TowPro.
Originally posted by stevensr34I've extended the wiring and moved it over to one side, behind and below the passenger-side headlight, where there is some airflow.[B][SIZE=4]ntp
Car sitting in carport, engine cold and guage says 37 degrees.
I think it's only 39 in the setting sun and it was 7pm!Dave
