Larger fuses only relocate the symptom or hide the problem they are not the solution.
current flow through a resistance causes heat, more resistance or more current equals more heat. Fuse blows cos it gets too hot because the current it too high for its resistance.
bigger fuse, less heat for the higher current... Problem is that higher current is now causing more heat somewhere else... ? Where, nobody knows...
plastic insulation melting? Does somebody smell smoke?
dont just increase the sizes of your fuses gents, they are set at a value for a reason.
