what was the part number for the cabin filter from Ozispares ?
Underbody fuel filter
Gday Razorback81
Originally posted by Razorback81 View Postwhat was the part number for the cabin filter from Ozispares ?
Westfil - WCF48
Both of these filters are for both the 120 & 150 series D4D's under the bonnet fuel filters! (The big fuel filter)
Both of these filter's can also be easily obtained from bursons/ Repco and super cheap auto!
PS ... Ooooops! I didn't read your question properly! The cabin filter as in pollen filter is "WACF5231" for the 120 series and "WACF0040" for the 150 series!Last edited by SWR; 05-02-2014, 08:26 PM.
thanks
so just to be clear
for the 120 D4D
WACF5231 for cabin pollen filter
WCF178 for the filter between the tanks above the tail shaft
WCF48 for the water trap filter under the bonnet ( for diesel engines)
i have been using the kit from Donaldson ($50) for air filter, oil filter & fuel filter when servicing my car
they are supposed to be equal or exceed the manufactures specs2008 Dune D4D manual GXL update - with lots of fruit !! + Roma Razorback Off Road Van
Gday Razorback81
Originally posted by Razorback81 View Postso just to be clear
for the 120 D4D
You will also find that Ryco & Westfil also meet/ Exceed Toyota's manufactures specs and well exceeds Toyota's pricing by a country mile! Lol
Originally posted by Skywalkerrun View PostGday Razorback81
Ryco - Z699
Westfil - WCF48
I just noticed (Now) that westfil updated there parts sheet today at 1am (06-02-14) and changed the part number on the 150 series from the Westfil - WCF48 to the now WCF104! .... The part numbers for the 120 series are still the same so don't panic!
PPs Don't get the pits with me as i am not the one changing or updating the parts list! Boooooooo!
cheers adds, didn't think so as I couldn't see it. One less thing the 1kz has to worry about!
Originally posted by adrian5800 View PostIt doesn't..
Ades2012 4dr JK wrangler, 3.5" AEV lift, AEV mags, 35" muddies, front/rear arb bars, tjm sliders, pioneer platform and some other goodies
Originally posted by Razorback81 View Postthanks
so just to be clear
for the 120 D4D
they are supposed to be equal or exceed the manufactures specs2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
Replaced the under-body diesel tank filter recently. For those who are keen to take this on it is relatively easy and takes no time at all.
Just look through this thread and there are some excellent instructions and images to assist.
Tip; after removing the two 6 mm bolts allowing the filter to drop a little, I placed a small blade screw driver in the hole in the front of the orange clip, reached around the back and squeezed together the 'legs' of the back of the two orange clips. This disconnected the 'teeth (one on each leg) and while holding these in levered the screw driver and the orange clips come out easily first go.
Not a job I would like to do on a trip but certainly doable if necessary.
I tipped the fuel out of the removed filter onto a clean cloth and it was spotless thankfully.
No need to tackle that job for another 20 k.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
Originally posted by brad_871 View PostFor those of you who already know, I apologise. I'm not trying to teach you how to suck eggs.
For those that dont know, there is a second fuel filter in the diesel models underneath the car next to the tailshaft. I finally got around to replacing mine today and upon inspecting the stuff that came out of it, I presume it hasnt been changed in a long time.
There were no distinct particles, but the left over diesel in this filter was black like used engine oil! It hadnt come through to the main filter (touch wood) but it's certainly worth being aware that the filter is there and needs replacing!
Brad.
Originally posted by Hazza View PostReplaced the under-body diesel tank filter recently. For those who are keen to take this on it is relatively easy and takes no time at all.
Hazza
Did mine on the weekend. Talk about bloody easy to do. Took less than 15mins.
Only thing I would say is don't get carried away trying to pry that orange clip out from the front on the hoses. You will break the tabs.
I undid the mounting bolts and that gave me access to the rear with my fingers I pushed the clips in and pushed and the orange clip came out and off came the hose.
Try eziautoparts.com.au $26.15 delivered for the same filter...Last edited by nathanbirss; 26-06-2014, 07:45 AM.
Did mine today. Not to difficult but the shit that came out of the filter surprised me. (Black and dirt particles) Found no record of Toyota ever changing this filter which means at least 200k on one filter. Had a look at the cabin filter also black and completely blocked.
Aircon works much better with new filter. This filter is sooo easy to change, no need to remove glove box just pop past the stoppers and slide it out. Less than $80 for both.
Originally posted by BlakMoth View PostWhy doesn't the old 1kz have that filter too?Dave
