thank you 1kdtech but geeeez... punctuation?
WHO HAS HAD INJECTORS REPLACED BY TOYOTA
Originally posted by pjorek View Postcan you or someone who's had these explain the symptoms of dodgy engine mounts? Is it vibrating when the car is in Drive and stops when you put it in Neutral?
You will feel it when the drivetrain is under load So the answer is yes it would vibrate more in gear (auto) as the drive line in under load.
