$1K for injector feedback test?!?! Avoid, avoid, avoid!!
Clogged Sump Oil Pickup
Originally posted by amts View Post$1K for injector feedback test?!?! Avoid, avoid, avoid!![SIZE=2]120 GXL D4D Auto, with a 'List of Wants' greater than the 'List of Needs' greater than the 'List of Haves'
What the flark is going on out there?
Perth rip off week?
Ok check oil pickup, with torch, while/after draining oil. It should be clear.
Crew, don't panic about this unless you have a 2006-2007 which has not has the copper seats removed.
02/2008 onwards its just a quick check, as its worth the 10 seconds.
IF, for some odd reason it's blocked, I charge 1hr to remove the sump & clean the pickup, that's all it takes.
You do not have to replace the oil pickup.
Injector diagnostic test anything from free, $50,$80,$100, anything more & tell them their dreaming.
New injectors, pipes, seals & gaskets, egr clean, plate up, etc, professional job if you can find one there, should its no more than about $3k
If you are unsure, you can call me for some free expert advise.
Just found the pictures I took of the first job I did on my 120 after getting it, thanks to advice from PP's, I dropped the sump and found this,
before and after a good clean.
host image online
picture upload
When I did the injectors 4 months later number 1 was passing, 2, 3 and 4 where good.
Inspections and oil change ever 6 months show no further build up.
Thank you all for saving me a likely engine rebuild.2007 120 D4D GX. Duel Battery, Secondary Fuel Filter, Safari Snorkel, Uniden UH7700NB/AT870 antenna, Scangauge II, King/Bilsteins lift. Rhino rack Pioneer Platform. Maxtraxs and homemade rack side mounts.Awning. And the to-do list is still long.
