Carbon Lumps from leaky Injector seals
G'day Fredrick,
Glad to here you are getting closer to getting on your way.
From what you are describing re cleaner inlet, you may have an engine that has less leak damage,
but just a word of caution, As I have mentioned before, the damaging lumps that block the screen get trapped in the sump floor, or on your oil suction screen face. This is because the drain bung internal to the sump has only a thin skinny slot in it to allow all the Oil to drain, but because it is thin & skinny, it holds the bigger lumps in that do the clogging of the screen. This is a bad design in respect to draining the oil. So it is less likely you will find them in your drained oil, although a rare few might escape in supsension.
From experience, Checking that screen properly is your only guarantee here Fredrick. If Aldi run out of tools, don't worry, I reckon a Mini mag light & a keen eye might get you by.
Regards & good luck
Landuser
Originally posted by frederick
View Post
Regards & good luck
Landuser
