Originally posted by sacred cow
View Post
Landuser,
Thanks for your excellent contributions to the forum. Re the injector seals, I do not agree though that it is relatively inexpensive to replace them. Someone has said that it costs about $900 - $1000. I have printed out the relevant part of the Workshop Manual and there are 5 pages of diagrams, 14 pages detailing how to remove the injectors and 20 pages of instructions on how to put it all back! It is not a simple procedure and there is scope for significant errors to be made and these could result in high pressure fuel leaks and possibly a fire, air leaks and coolant leaks, etc.
The fuel needs to be drained - surely not both fuel tanks but there is no explanation on what is meant and how the fuel is to be drained. What is required?
In petrol engines, there is usually a procedure to de-pressure the high pressure injector fuel rail before working on it. There is no mention of this. Is this because the diesel engine automatically de-pressurises at shut down? If not, what is the correct procedure?
The coolant needs to be replaced as does the oil filter and quite a few gaskets. Ideally the injector pipes should be replaced. So all up there will a significant cost for parts.
For some unknown reason, the manual describes the injector seals as "nozzle sheets". What do you do if you undertake the arduous process of finally getting to the injectors and the injectors are totally bonded to the housing with carbon build-up? Do you use something like carburettor cleaner/solvent?
Re-installation instruction 2.v has a Hint - "Never reinstall the union bolt on the engine." This seems very strange as 1.m has the instruction - "Tighten the union bolt." The union bolt is not marked as a non-reusable part on the diagram. Any thoughts?
For peace of mind I would like to replace the injector seals but feel the procedure is too complex and it may not be flawless. To me, it is a perfect case of letting sleeping dogs lie unless of course it is definitely known that the the seals are leaking. Then it is of paramount importance that they be replaced without delay. Therefore I would like to have the procedure clearly defined in case I need to implement it at short notice.
So I would appreciate any help possible with refining the procedure. If anyone is doing a replacement in Brisbane, could I come and help you?
Glenn
Glenn
