Originally posted by mackayvx
View Post
2003 kzj120, services were never more often than every 20,000klms, (lately 30k or more)
Did the radiator at just iver 100k, as it had the small leak at he sides these toyotas get.
Other than that bugger all, no glow plugs, no injectors, nothing else..... Well 1 set of brake pads,
It's close to 300k and rus real well. ( I can imagine the glow plugs, and how much better it could be)
They just don't want to spend the full preventative maintenance on it.
But they will buy a new one soon as they have got there $35k worth out of it 300.000k 10years......
This is what I mean, how far do you go?
I just think, based on a Toyota, kzj120, manual with full service history, it ant going to have a failure that stops you and leaves you sitting unless you are real unlucky. Typically it May develop an issue, but still be drivable. Like my gearbox, or a slipping clutch, I read one of these travelled 600k on a full battery with a screwed alternator, etc Etc.
I know replacing everything before it happens is reliability but its all calculated risk hey.......
I think the biggest concern for all is the issue of the transfer case getting stuck in low.
Once again not stopped the vehicle, but it will slow it down a lot!
I have heard from the towies this is what stops them, and in the high country a fair bit.
I can't wait to see how far these engines will go.......
