If anyone wants a copy of my spreadsheet which gives a running total , of consumption,cost per litre , average k's per litres, miles per gallon etc, send me a message.
Details per trip and average overall given for
Kilometers Travelled
Cost Per Litre
Quantity Litre
Total Cost
Cost Per Kilometer
Litres Per 100 km
Miles Per Gallon
Kms/ Litre
% fill
I have just bought a 2005 T/D auto with 29500kms on clock, first full tank of fuel with 300kms around town and the rest to Albany and back I got 12l/100km. It has Desert Duelers 275/65's fitted which I don't know if they are taller than standard to effect speedo accuracy I will have to check. I am keen find out about any mods for more power and economy.
Not sure if this thread is still alive and twitching so I'll post the question and see what happens... :|
I'm looking at getting a whole new exhaust for my 2004 3.0 Diesel 120 Prado. I went into the local exhaust shop here and the guy gave me a quote for a 2.75 inch Mercury exhaust system. $800 fitted. I don't know why he went for that one but he said they were pretty good for the money. I see there is a lot of info on this site about the Beaudesert setup, but is Mercury any good?
Thanks,
I have a april 2007 VX, My wife and i are sure something has changed when it comes to how much fuel shows what level on the gauge.
We have run 5 or 6 lots of 180L through the prado in the last 12 months and thought the gauge was pritty linear. But we are now seeing numbers like Blackbird's ( no the tank is not dinted now :-).
The weekend before last we put 30L in and it showed 1/2 on the last 90 tank when the light first came on. This weekend 100L after the low fuel light had been on for 40 km ( its a long way between BP stations when cutting wood in the bush here) showed 3/4 of the whole gauge , but after 10 minutes dropped to 1/2 of a whole gauge.
We get between 10.2 and 10.8 on the SGII averaged over a month.
2007 120 D4D VX Auto.
1985 LWB Suzuki Sierra 1600.
have just finished first tank on 08 D4D - very conservative driving
Rough figures (am yet to get exact speedo error) put economy around the 11.5 L/100km - Am a little disappointed but I do run 265/70 Cooper STs which i am presuming makes a big difference - out of curiousity at 100 km/h I am doing about 2100 revs - how does that compare to those with standard size tyres?
At first thought I had the quick reaction of "Im selling the STs and putting standard tyres back on" but having read through other PP reports - maybe a litte hasty!
Definately agree with the comments about the second tank going a lot quicker - At one stage I wanted to glue the little needle on so it stopped dropping so fast! :evil: - Is a lot more painful on a lease car knowing you have to keep driving it to get the kms up!
Hama, your right about the coopers, before I fitted them I was getting in the low 10's around town, now with the st's I'm averaging around 11.6 & on the hwy about 10.8
2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
yetiboy - what % error for your speedo do u work on? - I reckon about 4% is about right going by a couple of GPS's I have tested with.
I found that when I am doing 110 by speedo - the GPS says Im doing about 106 - I thought it was meant to be the other way round?? how does that compare with you?
First of all , you will get a full 1 to 2 l/100km back by the time the motor is run in at 12,000 Km or so.
Now for the tyres:
--cooper tyre-------------------
Height of tyre wall = 265 * .7 = 185.5mm
1/2 of a 17" Rim = 8.5" = 216mm
Wheel radius = 216 + 185.5 = 401mm
Circumference = 2 * 3.1415 * R
= 2522mm per tyre rev.
= 396 revs per Km
-----------standard tyre---------------
Height of tyre wall = 265 * .65 = 172.3mm
Wheel radius = 216 + 172.3 = 388mm
= 2440mm per tyre rev.
= 409 revs per Km
401/388 = 103.4 ( the cooper is in theory 3.4% taller)
take 3.4% off of your 11.6 and 10.8 => 11.2 and 10.4.
now lets look at the revs at 100km/h
Assume 3.909 diffs and .799:1 top gear.
Now for the tyres:
= 396 revs per Km
= 409 revs per Km
