Originally posted by MRW82
View Post
Catch Can Install
09/08 Prado GX D4D White, Auto, Option Pack 1, Soveriegn Bull Bar, 2" Ironman lift, Ironman snorkel, catch can gone EGR blank with 6mm hole installed
yes its the same as the provent 100. I had to modify the drain, it was just an open barb, which I cut off and tapped a 1/8"bsp thread into for a compact push in fitting. You could possibly mount it a bit higher and use it as it is, but then the holes won't line up as well for the bracket. And it was hard to work around the intercooler support bracket with the hoses, that's why I ended up using copper plumbing bends.
I've only had it on for about 1000km, but the drain line is still empty. The hosetails on the catch can are 19mm, the PCV hose on the prado is 16mm so it should flow more volume than the car requires.
Thanks, did you make the bracket?, good idea with the copper bends they look like they fit good onto the 19mm outlet/inlet have you reduced size out of the bend to suit the 16mm hose onto existing fittings09/08 Prado GX D4D White, Auto, Option Pack 1, Soveriegn Bull Bar, 2" Ironman lift, Ironman snorkel, catch can gone EGR blank with 6mm hole installed
Made the bracket myself, after a lot of thinking on how/where to mount it the bracket ended up being quite simple.
The 3/4"(19mm) copper bend fits neatly over the barb on the catch can, with a bit of loctite so it doesn't move. Then a short piece of 3/4"pipe which 5/8"(16mm) pipe fits inside to be silver soldered and then the hose clamps on neatly.
I think I've still got dimensions for the bracket if its useful to you, keeping in mind the drain fitting will need to be modified.
Originally posted by MRW82 View PostWhy is that?
I personally have fitted many provent 100 n 200 . Too many diesel vehicles .
You shouldn't have to empty it to often,
Here is a pic of the provent on my 150 series
Originally posted by MidLifeCrisis View PostMy install is the same position as MRW:
[ATTACH=CONFIG]16405[/ATTACH]
And where did you get it and the can from?
Thanks2006 GXL, D4D, White, Sovereign Bar with Winch, 265/70r17, 2" lift, Recovery Points, Max Trax
Thanks[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
I thought your AVO was meant to stop you stalking people.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by was a 75 View Postjust curious if anyone has installed in front of radiator/ac condensor? the gap between that and the bonnet grill looks big enough to accommodate the 200. run out of room in engine bay[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Originally posted by mjrandom View PostI thought your AVO was meant to stop you stalking people.[B][COLOR=blue]Bitumen: A blatant waste of taxpayers money![/COLOR][/B]
Genuine Provent or a copy? Could be the bracket.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
