Gday roo
Yep!!... Another "HUGE" read for those none mechanical minded out there that want to learn the truth on facts!.... That is what is supposed to separate a forum from a dealership and workshops!... Un-bias truth with no hidden agenda's!... Lol
I haven't bought fuel injectors off these guys (http://www.amayama.com/) as i bought mine from someone that i "thought" i trusted and like most people i believe i also got shafted (Reconditioned) and for this i am now on a mission to pay back the favour to the industry as a whole with facts based on truth!
There is still quite a few good/honest guys (Like your self roo) trying to make an honest crust but i feel the industry is becoming a tad greedy and miss-leading in the fine detail of wording and cashing in and taking advantage of the average go-blogs hard earned cash.
I have ordered parts from these guys and they do look extremely authentic! The packaging i got for the washers etc. was all in Japanese and look's very authentic!
If you are ordering from these guys three weeks wait is not out of the norm so ordering up-front would be a smart move! Lol I also used paypal to hide my credit card details but i am like that with everything.
Toyota sell parts just like any other car manufacturer but they like all the other manufacturers also pay others to make them so i guess the rule applies globally EG: Toyota mark-up from denso and denso mark-up from who-ever and maybe who-ever from even someone else.... Lol What ever the story they are better priced and work just as good as denso/toyota and look extremely identical as a few other guys have pointed out with the parts they have bought
I also found out with intense research that the copper coated seating washer for the fuel injector is actually a heat shield washer and one of main cause for injector failure is microscopic silka particles in the fuel!.... High flow 2 micron filters play a critical roll as well as keeping out that water or shall we say moister.
Silka is the aquiverlent of sand paper (Microscopic particles) running at very high speed (More relevant at high fuel pressures) through the fuel system & causes extremely abnormal wear on the injector ports and high pressure fuel pump etc.
Average life of a common rail diesel injector "can" be up to 300,000km but it can also be as low as 60,000km with poor filtration of the fuel given its environment.. (Dry sandy environment and poor fuel storage).
This is a must read if you want to understand your D4D despite this is mainly referring to commercial!... Also ignore promo as i put it up for the informative information!
https://www.hyprofiltration.com/clie...&%20Slides.pdf
I believe the fuel passing through the injector acts as a coolant to help dispearse heat for the injector but on the flip side of the coin one of the many contributions to life reduction of the fuel injector is the heavily reduced sulpha (500PPM to 10PMM = Parts Per Million)... sulpha being a good lubricant... Also the return fuel to the tank heats the tank fuel and can cause condensation in the fuel tank on cool days. So many variables with the fuel algae and bacteria etc. Not forgetting the very high fuel pressures just add to the big picture in the extreme circumstances.
Ever noticed how stock standard highly abused d4d's in the mines and desert are living longer than the average pimped-out diesel suburban despite the commercially run D4D's having the odd's stacked against them from a percentage point of view?
This is also a good read on engine stress. Admittedly its on boats but the same rule applies!... "Engine stress".
http://www.mvdirona.com/TechnicalArt...neOverload.htm
I believe the main reason for the turbo intercooler being re-located is for the ever tighter emission laws to scavenge as much cool air as possible for the manifold intake cooling with minimum heat absorption exposure as possible... Intake air (heated via turbo compressor) and EGR (Exhaust Gas Recirculation) will always be cooler than peak-duration combustion temps and the min 84 deg Celsius temps that are being pulled from the coolant radiator when the thermostat opens (also being compromised with the heat from the a/c condenser and turbo/exhaust temps will always climb very high in the engine bay when stuck in traffic or the poor air flow due to high RPM in low gear EG: driving sand dunes or climbing steep hill in low gear with engine under heavy load.
Just sharing my thoughts on it all and manufactures will always re-configure the engine management as technology changes for the better.
