Timing Belt 07 D4D
  • Timing Belt 07 D4D
    Hi Guys
    Getting some work done on the prado. Timing Belt & Water pump.
    Received a quote from toyota for the parts & i think they have given me 150 series numbers for the timing belt.
    Can any one confirm what i need including extras (crank/cam seals etc) and if the below list is correct and all thats needed
    Dont want to go to my mechanic with incorrect parts or not enough.
    So far i have
    1356839016 timing belt
    1350567041 idler
    1354067020 tensioner
    9031132019 x 2 seal oil camshaft
    9031132019 front crank seal
    1610069356 water pump
    9091602511 drive belt
    07 GXL D4D Auto
    265/70/17 Cooper St, ARB Dual Battery, IP900XS Spots (crap), Black Widow Draws, Cargo Barrier,Billy Lovell combo, polyairs, reverse camera,
    I think you can confirm those numbers here
    http://www.toyodiy.com/parts/
    Gavin
    2008 KDJ120
      thanks, just checked and timing belt for 120 seems to be 1356839015.
      Is there any other parts required for the timing belt and water pump changover?
      I also came across a few threads on Amayama Trading. What is the consensus here are they the real deal as their prices are cheap.
      07 GXL D4D Auto
        Hey just wondering if u could let me know how much this cost you? We are thinking of getting a d4d that will need this done soon. Need to know costs please.
          Interesting?? For starters there is only "ONE" camshaft seal and the crankshaft "Harmonic" is a totally different seal??... So why "THREE" of the same seal?? ... Lol
          I'm guessing they would be cashing in on parts and labour for parts they have no intention of changing!
            I'm about to clock 100,000km and will have the local Toyota dealer do the timing belt ($400 parts and labour!). Should I get the water pump done at the same time?
            Based on the other threads I guess I better get the sump screen and injectors checked while I'm at it......
            Huge thanks to my 'virtual mechanics' at Pradopoint, can't find a mechanic I trust that much in Nairobi )-:
            07 Prado TX, KDJ120W (D4D)
              I thought the timing belt is at 150K Km - but an ounce of prevention....
              Personally, I agree to get the water pump done at the same time.
              What I would do this service (and expect a possible big bill with this) is get the injector readings (both cold and hot), vehicle will have to overnight.
              IF the dealer has done the 80K km service properly, the injectors would have been pulled for inspection and sheet and o-rings replaced. If this was not done, ask why and push for them to do it properly at their expense. Otherwise you might have a time bomb....
              Screen inspection is the go, if they have the capacity for a inspection camera - demand to see the image.
              I learned the hard way, don't want anyone else to have to go that route.
                Thanks, will be doing the timing belt now partly because I'll likely have to sell it in about 50km or so. I'm worried about the time bomb issue since I drive in some dodgy areas and hope to do some long drives soon (my last was 7200km and I was thinking injectors the whole time....). Everyone here seems to think all you have to do is run the detergent through the system regularly.
                  I have been advised by my non toyota dealership mechanic that i should replace the timing belt damper & tensioner when i replace timing belt.Can anybody advise if necessary or if that had problems with the said parts in the past.
                    Refer to this link:
                    http://www.pradopoint.com/showthread...nsioners/page1
                    Winston.
                      without a doubt.
                        Highly recommended. My non Toyota mechanic did it, no question.
                        All comes in the kit, I think..
                          Thanks for all the feedback guys. I will be having them replaced, CHEERS
                            Currently looking to replace the timing belt and water pump shortly.
                            Re the required seals, can anyone confirm with partnumbers which seals require replacement?
                            1 x 9031132019 CAM SEAL
                            But I believe I am missing other seals?
                            This kit shows two other seals but I dont have a reference part number for them, can anyone assist?
                            http://www.onlineautoparts.com.au/bu...ne/ZPN-05500__
