I live near the snowy mountains so during winter the weather can be quite cold.
Over this winter I have noticed the engine getting noisy-er at start up but perfectly quiet when it is warm.
When I start it I get a bit of a crack on what is probably the first cylinder and a little exhaust smoke which disappears immediately. The engine remains a little noisy (like a big end type noise) until the coolant reaches about 40C - I have a scan gauge so I know! This is a noise that increases with revs. (Could be leaning out?)
In the last week the weather has warmed up and guess what? No crack smoke or engine noise on start up.
I believe the engine to be in good condition (100k), the oil fresh and of the correct viscosity. There is no debris on the oil pickup so the injector seals must still be ok.
My theory is fuel temperature.
Why I say this is because the motor on start up is (currently) the same temperature (or at least the coolant is) as during winter, and this I think eliminates oil thickness concerns. Any noise dissipates when the engine achieves coolant temperatures exceeding 40c.
I am about to get a fuel test of the injectors in a couple of weeks which should be informative.
Is it likely injectors perform less efficiently when they are cold?
