Hi all not sure if someone has already asked this but I have a 05 model prado pre common rail and was reading somewhere where you can block the Egr valve. just wondering if this correct?
Egr Valve blocking
Originally posted by mick.ang View PostHi all not sure if someone has already asked this but I have a 05 model prado pre common rail and was reading somewhere where you can block the Egr valve. just wondering if this correct?
I did the old ball bearing in the diaphragm vacuum line trick. But on an older vehicle it may be best to insert a plate between the valve and manifold because over time the valves leak at the seat or are stuck partially open anyway.
Originally posted by Brad_kosij View PostDoesn't it bring on a constant light, when i got my injectors changed they didn't put a vacuume line on and it kept bringing up a light on the dash.
Does the computer change the fueling because of it?
Fit a catch can to the 1kd instead.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
