Originally posted by D4D
View Post
D4Detonation
Originally posted by MRW82 View PostUpdate: injector values are out of tolerance on cylinders 2 and 3 (injector 3 reading a value of 5!) these same injectors were perfect just under 10000km ago. Suspect that contaminated fuel has caused the injectors to fail. injector 3 failed catrostrphically dumping mass fuel into the cylinder causing hydraulic lock and there is assumed damage to the piston, cylinder 3 has NO compression (other cylinders are within spec)
awaiting insurance assesment and praying like a born again Christian that they approve it and cover the damages.
Stressful couple of days for us lately.
I believe another well know forum members D4D has also failed as well...
They are dropping like flys.
I can see Toyota just hoping they dont have to do a recall. Imagine the cost to replace for all those D4D's seals out there....[B]Robert
When they take the injector feedback values, do they remove the piping or injectors?
I am more concerned if anyone that works on the car at service, does a good job. I.E: if they have to touch anything in the fuel system and break open the sealed system, removing filters/pipework/injectors etc, that is working fine when it goes in. Are they meticulous that they don't allow any contaminants into the fuel system. It seems to be a common story, car goes for service, blows up within 10,000klm.
I do all my servicing, making sure the engine bay has been recently washed or is clean and really make sure I don't get dirt near anything. I don't think service centers take the care as they are under the pump to get the job done.
I wish you all the best!
Cheers Brad.[B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
Cheers Brad.
Originally posted by ttmx83 View PostWhen they take the injector feedback values, do they remove the piping or injectors?
Cheers Brad.Originally posted by Beach View PostI'm with you on that one. Especially after my one and only experience at a Toyota stealership. Really these people are all about the turnover and only see customers as cash cows. Fortunately I have a good mechanic I can take my vehicles to.
From what I've seen, pigs...... Even changing fuel filters, this is where you need to be soooo careful & clean.
Welcome to the Prado engine buster club.Dave
Been a while so time for a bit of an update. Got the prado back 3 weeks ago and am loving driving it again. Performance is on par with how it ran before, not driving hard as its still running in. Although the last 2 days it has seemed a lot more torquey, maybe its my imagination, maybe its improving as it runs in. Done over 1000km already so its back at the mechanics for an oil change.
Anyway, got some pics of the busted piston:
Nice crack. Good to hear your back in your Prado. Mine took 8 weeks to fix.Dave
Looks like I am a new member of the D4Detonation club. Car is on transport from Katherine to Brisbane after the motor failed while we where in Kakadu. I run scangauge and noticed the temperate increased to 94 from the usual 86-89 and then smoke then pop pop pop at 2500 rpm. Turned off immediately but the damage is done.
We had the injectors replaced at 150000 after the cold noise but now with 200000 we have expensive problems.
Bugger.
Rusty.08 VX D4D, Lift, Safari Snorkle, Trailblazer Fridge, Custom Storeage System, BFG, ARB Safari Bar, Wife, Kids, Codan NGT HF Radio, Debt.
Originally posted by Rusty62 View PostLooks like I am a new member of the D4Detonation club. Car is on transport from Katherine to Brisbane after the motor failed while we where in Kakadu. I run scangauge and noticed the temperate increased to 94 from the usual 86-89 and then smoke then pop pop pop at 2500 rpm. Turned off immediately but the damage is done.
Bugger.
Rusty.
Did the vehicle have any symptoms? Knocking? How long since values were checked?
Bugger.
Rusty.
Sorry to hear that mate, hate when things like that happen whilst on holidays.
Can you tell us what injectors went in at 150k kms? Baileys?Denso? Were the seats/sheets replaced from the copper to the new ones?
Used the denso new units with the new style seals. Have ordered the Bailey units for this rebuild. Valves were checked at 150 as well.
The cold knock had started again but only days before we left. Not as bad as the first time but this was possibly the start. We towed the camper for 3500 km before the failure so who knows what really happened.
Photos to come when motor pulled down.
RustyLast edited by Rusty62; 02-09-2014, 05:15 PM.08 VX D4D, Lift, Safari Snorkle, Trailblazer Fridge, Custom Storeage System, BFG, ARB Safari Bar, Wife, Kids, Codan NGT HF Radio, Debt.
