clean it out with brake cleaner while you are there
also clean the air flow sensor in the air cleaner ( dont use brake cleaner on that though there is another cleaner for that)
then i will go a lots better as well
and you should fit a Pro Vent, that will help stop that residue going through the EGR and all your hoses !!
