2008 1kd-fte: P0046 Boost Control Solenoid Circuit 1 Failure
    hi all.
    our prado has been off the road for over a month now. the fault code we are unable to clear is P0046.
    we have gone through and checked everything, and the T11 connector shows above 1 ohm for all the pins.
    T10 DC motor works fine.
    T8 turbo motor driver is fine. (has been replaced)
    T11 nozzle vane position sensor is fine. (has been replaced)
    as far as we can work out, its down to the loom/wiring.
    can anyone help with this? or are we going to have to replace the loom to fix?
    thanks in advance.
    SIK-120
    2008 Toyota Prado 120
