Hi Rick. The power doesn't seem any different! Not that I am a lead foot to probably notice the difference anyway. I will probably notice when I tow my trailer on the weekend.
diesel rattle in D4D Prado
This is a sticky topic.
Hi there
Can any one recommend a good diesel mechanic in Adelaide to check my injectors re the "engine knock until warm issue"?
Doug[B]02/2007 "Ultra Rare White" 120 Prado D4D M6.[/B]
Black widow roof rack, Window tint, Airtec snorkel, ARB awning, ARB OutbackSolutions draw system, IPS XS spotlights with driving covers, NewPro-Tech turbo timer, PolyAir springs, TJM XGS Gold suspension inc strut top mounts and 50mm lift, Milford cargo barrier, TJM under body armour.
In the future there will not even be a button because the car will scan the environment ahead and automatically select the correct gear and range required. You'll be a passenger in your own car and a little chip will pilot it about the countryside.Dave
psycho did they inspect the oil pick up screen? The injectors you can hear and feel as they get lumpy but oil starvation can creep up on you.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I dropped the sump after reading all the posts in here since joining mjrandom. (Why did I add bash plates). Oil pickup was clean as a whistle. My neighbor (diesel mech said it was in great nick) He mentioned I can buy a flush treatment but didn't think it needed it.
Am now just waiting for the oil leak to start like every other car I have ever dropped the sump on! :-(
Dave...
Good news despite the inconvenience.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
More goo says the roo.Dave
Typically, a leak between the engine and gearbox will be the rear main seal. You'd be wasting your time using sealer.Dave
Not happy. My Intelligent Tester, which I have used only twice, has decided to stop working. It freezes on the model input under the system panel. Won't let me select the model. About to head off into the great outdoors for 2 months and can't do my monthly injector test.Dave
Guess the only thing you can really do is to reboot it. If that doesn't work try the other foot the next time.Originally posted by Bushbasher View PostNot happy. My Intelligent Tester, which I have used only twice, has decided to stop working. It freezes on the model input under the system panel. Won't let me select the model. About to head off into the great outdoors for 2 months and can't do my monthly injector test.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Bushbasher,Originally posted by Bushbasher View PostNot happy. My Intelligent Tester, which I have used only twice, has decided to stop working. It freezes on the model input under the system panel. Won't let me select the model. About to head off into the great outdoors for 2 months and can't do my monthly injector test.
What make is it? Is it a Chinese job?
I have been doing a little research on these things as I want to keep on top of my injection equipment.
Sorry to hijack this thread!Shifter.
2007, GXL, D4D Auto, Racor 230 filter with 10 mic (98%) cartridge,
Yes, it's Chinese but what computer isn't these days. Made under licence from Denso.Dave
