Gday Shifter
I believe the answer you are looking for is "How does the ECU know the injector values!).
I will give basic description to the best of my knowledge as too many other sensors in the big picture involved.
When the injector is assembled (wether it be of solenoid or piezo--piezo responds 4-5 times faster than solenoid) they are flow/crack tested (Crack being at the point it opens) and then given a 16 digit calibration (Compensation) code. Impossible for two of the same injectors to give same flow/crack-point hence the compensation code!
The code is so that the ECU knows exactly how much fuel all cylinders are getting and to give accurately and can compensate accordingly.
Now all the above is sorted in a basic manner you can now go one step further!
The ECU measures the resistance feed back from the injector (Combustion/compression load pushing on the injector Vs resistance feed-back on the tip... Not forgetting crank angle and RPM etc.) which will influence the resistance feed-back to the ECU when the injector is energised... This in turn gives the ECU the capability to compensate more or less fuel to each single cylinder to keep the engine running smooth and evenly.
If one cylinder drops in power (for what ever reason) the ECU will make the next in line cylinder work harder by putting in more fuel (If cyl 1 drops cyl 3 will get more fuel) Firing order 1-3-4-2.
If an injector was to start abnormal wear and tear this would show up in the feed back resistance based on the 16 diget calibration code and known fuel rail pressure which is read from the fuel rail sensor switch! Switch is also a fine calibrated resistance feed back. (ECU has incredible call-up maps with equations of variables).
The fuel rail sensor not only tells the ECU its line pressure but inturn the ECU then controls the electronic fuel rail pressure relief valve.
As you can imagine! If rail pressures are changed so is the calibration of fuel to the injectors.
If fuel line pressure is too high or too low The ECU would know this under normal circumstances (No shim fitted to the fuel relief valve and no corrigulation of the fuel sensor switch) and fault codes or limp mode would follow if mapped parameters are not met!....... I would call this a "Safety" feature!
When the injectors are manufactured they are manufactured to work within certain fuel pressure tolerances.
