D4D Engine Failure Survey (Hilux, 120 & 150)
This is a sticky topic.
  • D4D Engine Failure Survey (Hilux, 120 & 150)
    If you are a 120 and 150 D4D owner that has personally experienced engine failure due to the injectors or blocked sump pickup, can you please fill in this survey? If you know of other owners who are not on this forum, you can also share the link below to them.
    http://goo.gl/forms/bpJSYjq0Zx
    Link to survey results https://docs.google.com/forms/d/1_lp.../viewanalytics
    amts
    Ninja Poster.
    who's survey and why is all i want to ask?
      The aim is to find a pattern if there is one.
      The survey is mine.
      The survey link can be posted any where. I've only posted here and a few Prado groups on Facebook.
        Complete failure only or also injectors out of specification?
          Complete engine failure
            I had a very near miss. If I hadn't noticed the smoke on startup when facing downhil, my engine would have died. But I guess that doesn't count.
            Greg - 08 D4D Prado,
              Did you have a leaking seat/sheet?
                Yep it was the new version and was shown to be leaking and replaced by Baileys. They said it was the only new version one they have seen leak. Also said it was rare to see a leak if the vehicle not used for towing.
                  Sure but what engine failure do I choose? The blocked sump or the failed Baileys Injectors?
                    It's usually one or the other isn't it?
                      How do we see the results after completing this?
                      Rusty.
                        Well, no one said my injectors failed but I had a holed and cracked number 1 piston and cracked number 3. I did assume and put it too injectors but.....
                          Rusty.
                          I'll post up a link once there are enough responses (say 100).
                            Thanks.
                              Bump. 21 responses so far.
