Hi all im having problems with my fuel filter in my 120 series gxl prado I've gone through 3 this week alone not sure how to rectify the problem unless there is away to clean the tanks I've tried additives to get rid of any potential water in the tanks but no luck
Have to change my fuel filter every 100km help
Originally posted by Harris1 View PostHi all im having problems with my fuel filter in my 120 series gxl prado I've gone through 3 this week alone not sure how to rectify the problem unless there is away to clean the tanks I've tried additives to get rid of any potential water in the tanks but no luck
Are you saying that the fuel filter (under-bonnet one) is getting clogged? Does the filter display huge build-up of contaminant? What about the in-between tank filter? If you can clog that big filter in 100km then you have some serious business going on inside the tanks. They will most likely then need to be removed and cleaned.Dave
