So today i decided to do my Timing Belt & Water Pump as my Tbelt light come on.
I located the Top Cam timing mark and thought to what i could see the bottom one being aligned. After this is Went to do my Waterpump and realised i needed to take the camshaft pully off so i undone it but during the process turned it around a bit and then brought it back upto the mark.
Now i believe i may be 180 degrees out is there a definite way to check this as when im looking at my bottom pully mark its out but im sure i did not turn my crank at all.
Bloody ended up with a mess here or maybe way over thinking it
This is how my Bottom Timing mark is sitting now Can someone help me out with the correct procedure to rectify?
