I am planning to change the coolant in the Prado on the weekend as we are heading to the snow on the following weekend (just making sure). Is there a drain on the block somewhere to drain that as well as the radiator? Also is there a bleed valve somewhere that I need to know about or should I just run the engine with the radiator cap off for a while to get rid of the air?
Thanks in anticipation
Scott
Scott
