Has anyone adjusted the injection timing (1KZ-TE)? I think I could try to adjust it a little bit earlier. For the power and the fuel economy, you know. :wink: Toyota might be adjusted it for emission laws, not for optimal power.
I know there is a punching line and upper processing surface which should be aligned. Little bit more space between those... to the upper edge? Would it make couple degrees or even 5?
