G'day
Is there an easy way to remove the oil filter as it seems to be buried way down there ?
Ross
Hi Ross,
The 3l D4D is a breeze to remove compared to some others,
1. The toyota oil filter D4D Oil Filter P/N: 90915-YZZD2
2.OIL FILTER REMOVAL TOOL: PART NO. 09228-07501 or you can get a universal filter removal tool suitable for a socket set extension bar from Supercheap or REPCO make sure it suits the oil filter
3. Get yourself and long 1/2" or 3/8" drive extension bar 300mm + or make up a suitable length from your socket set bits and pieces;
4. Set up your oil drain container under the sump plug I normally drain the sump pan oil first, get yourself a small set of steps or 20L drum to stand on so you can reach filter by hand and a guard protection cloth;
5. Fit the filter removal tool and socket bar/ ratchet to the filter and back the oil filter off about 1 turn;
6. Dirty Oil will drain from the filter to the oil catch all and will drain via an "as fitted" plastic tube alongside the sump into your oil drain container;
7. Allow the filter to drain for a few minutes, it is easy to observe when the oil is finished draining down the small drainhole located at about 6 O'Clock;
8. Unscrew the old oil filter by hand, prepare the new filter and fit as per packet instructions;
9. When the new filter is installed and tested for leaks, I squirt a small quantity of degreaser around the filter assembly and allow it to drain down the drain tube into the dirty oil container, when I get the truck outside I then hose off the oil filter housing assembly.
WALLA all Done and Dusted
I bought the Toyota Oil Filter tool about 6 months ago in Melbourne direct from the Toyota Spare Parts counter and was charged $34.58
I'm not in the trade and also pay GST.
I thought it was a reasonable price for the genuine article.
Adrian
Adrian.
Prado GXL 3.0L T Diesel Manual 2007 (update model). Colour: Chrystal Gold (previously called Dune). Trim: Ivory. Compliance plate date: September 07. Build date: August 07. Sovereign bull bar. Toyota tow bar. Head light protectors. Bonnet protector. Insect screen for front grill. Rear wind visor. Cargo mat. Hella Rallye 1000 driving lights. Front side window weathershields. Reverse sensors. Roof rack bars. Standard vinyl spare wheel cover. Custom made sheepskin seat covers front & 2nd row. Tinted driver & pax window to match 'privacy' glass on rear windows. Ordered 9 May 07 & delivery on 2 October 2007 but well worth the wait. Oh what a feeling !!!!!
Adrian
I also bought the Toyota oil filter tool (Southside Toyota Brisbane, quote the part number as they won't know what you are talking about, 2 days from warehouse) for $34. It's absolutely the best way to go. I tried a supercheap socket type tool that "grips tighter as you loosen" but you can't use it to tighten a new filter. Obviously you don't need to tighten much but you just can't get hands on to do it. I use 2x30cm extensions and stand on a milk crate as it is.
Get the Toyota part, as others have said on the forum before, and keep your sanity.
